Hole in the seat material
nitrotmann
nitrotmann
80
224
  1. 1000 6 Crew
Didn't see any topics when I searched on patching one of the Honda Pioneer Seats. My stupid self set my heat gun down on the rear seat and burned about a one inch little spot in the seat. Wondering what folks are using to patch that seat material?
Thanks
Sent from my SM-S908U using Tapatalk
Fatsquatch
Fatsquatch
Approved Member
121,356
1,011,770
Hidden
Thanks
Everyone I’ve seen talk about a seat tear on here replaced the seat or put a cover on the seat until it got wet and then replaced the seat when they couldn’t get it dry. I don’t recall seeing anyone attempt a patch.
DRZRon1
DRZRon1
1,446
4,421
Thanks
duct tape - if u use red - +3HP
5,748
26,398
HEY!!!! Iz yore avatar a WHITE Talon?
bumperm
bumperm
1,929
6,828
Gardnerville, NV
You might try a two step fix. Put masking tape around the hole and maybe 1/4 inch from the hole edge. Use some 3M black weatherstrip seal/adhesive, lift the area around the hole to squirt some of this stuff in there. Next push in a piece of plastic screen material and get it flat and even-make sure the 3M glue is both over and under screen material. Coat over and even out the hole with the 3M stuff and allow to dry.
