P500 Home made 2" snorkel
Z
Zombeaver
44
52
Texas
Cut intake neck behind driver. Used 2" rubber sleeve with stainless clamps. Drilled one hole through steel behind driver head test used 5/16" bolt with lock nut to secure.
IMG 2506 IMG 2501 IMG 2500
Reactions: trigger and drfubar
solrus
solrus
1,629
2,511
Montana
Everything else is snorkeled also? Can you shut the engine off if you cover your air intake?
lipcurl
lipcurl
34
78
Hamilton
Nice job ! Thanks for sharing. I will be doing the same to mine after hunting season
Z
Zombeaver
44
52
Texas
If I place my hand over the intake (top of the 2"pipe) I feel it sucking and I can hear the engine start bogging like it is choking so I remove my hand. I have not choked it until the engine dies though. I also placed a couple of old socks over the top of the intake to keep any larger things like mud daubers out. :)
Someday I will probably paint the pipe also.
Reactions: Talen
So I take it the intake is 2" at the box? I've been contemplating ordering a warrior snorkel riser but didn't know what size.
Z
Zombeaver
44
52
Texas
Well the factory intake is 2" so that would restrict the air intake flow no matter how large the rest of the system was nearer the engine.
Yes.. I just didn't know what size the factory was.. I didn't want to order a smaller snorkel riser and have it restrict the intake.
