L
I would like to start out by saying that I have always been a Honda fan and we have always used Hondas on our family farm. Over the years we have had dozens of them from motorcycles, three wheelers, ATVs, and now Side X Side. Sadly the Big Red is probably going to be the last Honda piece of equipment we own. The quality is of the Big Red is to say it lightly poor. First the starter went out of it when the magnets just looked like they deteriorated in a million pieces. Next the crankshaft sensor went bad. Then it was the motor because of the brilliant idea to suck in clean air from the dirtiest place on the vehicle, under the box. Then the starter went out again along with the starter torque limiter. When your driving in four wheel drive sometimes the CV Joints just pop out of the front differential. Not only does it have lots of breakdowns but nothing is easy to maintenance or work on. The motor is sitting down in a hole where you have to disassemble half the plastic just to change a spark plug. Even changing the oil requires quite a bit of disassembling. Also Honda only warranty there parts for 60 or 90 days so you may as well go by Chinese aftermarket that have the same length of warranty.To say the least we have not been happy with the quality and the next one will not be a Honda.
