I just used a piece of 1-1/2" thin wall PVC capped on both ends and painted black, secured by two 1-1/2" PVC strap clamps attached to the roof with two 1/4x20x1" elevator bolts with rubber seals. It is mounted 3-1/2" higher than it was and well above the Honda roof so that I can see behind me in the rear view mirror again. Also, the lower bar where it originally hung provides support at the bottom so that it doesn't list forward at the top pushing rearward at the bottom, or essentially, more vertical.
