Muv700 honda big red I bought 2 2012s from a on line auction both were said to be in operating order I had to travel 5.5 hr to get to the pickup anyway I was late getting there and they had moved them out side the fence towed or push
Anyway when tried to start nether would crank I jumped 1 off and gas was hung wide open got fixed
Jump the other 1 off and it cranked but would backfire everything on the led dash would blink on and off as it backfired so I kinda figured it just need a hot battery got a battery and put it in it now cranks with out a boost but still has the same problem with backfiring and light's on dashboard blinking on and off then I discovered that it ran a lot better with the lights on so figured it was grounding back thu the lights and sure enough I found 2 grounds broken off fixed the now she run like a top but it will only change from 1 gear to 2nd 1 time
You can reset the computer and it will do the same exact thing ever time when it does this the engine light comes on and - sign comes up on the left side of the screen speedometer doesn't work at all ether shows 0 all the time has anyone else had a problem like this and if so what did it take to fix it
Ps I have had many honda products in the past still have recon 650 and love it and the transmission that is why I got the muv700 big red over any other s x s
