P1000 Honda OEM Fabric Front Doors
P
PDogRex
70
349
Central MT.
Looking at getting some of the Honda OEM Fabric Front Doors, would be interested in comments on how people like them or dislike them.
Also can these be removed say for the spring and summer time and reinstalled fairly easy?
These would be installed with the Honda OEM windsheild and hard roof.
Thanks,
Rex
Hillbillytnt
Hillbillytnt
517
1,897
Ky
Thanks,
Rex
I have them and like them. They work well with the Honda roof and windshield. They are not perfect or airtight but keep the wind and rain off of you
Russ989
Russ989
22,561
146,474
Thanks,
Rex
Honda Pioneer 1000 Soft Upper Doors
104,952
Use the 🔍 upper right hand corner of the page and select Threadloom results And youll see that your question was asked almost as much as much as “what's the largest tire can I put on a stock machine” question 😂
HBarlow
HBarlow
1,618
6,009
Daniels, WV
I also use a Honda windshield, roof, fabric upper doors, and hard cab back. I'm completely satisfied with all the components. I don't remove my fabric upper doors but don't see any reason you could not if you choose.
tjoreo
tjoreo
1,010
1,929
Southern Idaho
I have the honda upper doors and have been very satisfied with them. After the door install though, you will find the other places the wind and elements leak through. (Might look into Montana's shifter cover in the winter) I actually pulled mine off this weekend and it takes less then 2 minutes per side. There is a thumb screw in the rear section of the door that needs to be removed and 2 screws in the door bracket that need to be loosened. Then its simply pulling them up and off to remove. There is a section of plastic and weatherstripping that surrounds the upper part of the door, that I remove in the heat of the summer. It is a little more in depth to remove, but still pretty simple. I remove mine, but a friend of mine has the same doors, and he leaves his on all the time.
cattmann
49
114
canada
Thanks,
Rex
used them this winter and love them Best seal out of all 3 sxs sizes .I have installed all 3,the 500 and 520,the 700 and the 1000.They are very easy to remove.One small bolt at one end of each door which has a plastic knob on it and is hand tight and pull up .Thats it
