P1000 Honda OEM switch panel molex connectors for lights
338fedman
17
36
Alaska
I have the factory switch panel with the heater fan switch and wiper switch mounted. I discovered there are two prewired circuits for auxillary lighting there already, assuming one would use Honda factory light and switch. The fuse box under the hood has two unused molex 2-pin receptacles avialable.
Thinking i might want to use this to easily wire in a couple lights, does anyone sell the molex pigtail and the required switch to make this work? Seem like a waste to know use them if they are ready to plug-n-play.
Thanks.
Reactions: Lady01 and GrnP500
338fedman
17
36
Alaska
91A9C36B F3A2 498F 8707 648F64F84B1D
F130CB6D 63F2 4D3A 93CC 3D869299CE7A
Reactions: Lady01
Fatsquatch
Fatsquatch
Approved Member
121,572
1,013,516
Hidden
Thanks.
@Hondasxs probably knows something about it
Reactions: Lady01
bumperm
bumperm
1,931
6,829
Gardnerville, NV
I abandoned mine in place, there were 3 on the SE (IIRC). Like yours, they didn't provide for switch lighting etc. So it was just as easy to use female Faston terminals with after market rocker switches, as I was putting in a fuse block in any case.
One thing I for sure would have done different, I'd of removed that stupid large warning placard a lot sooner. Cutting a hole there makes wiring so much easier it ain't funny! This shows the initial hole, but as I mounted new things in this spot, most of the center got removed.
20210826 203158
68,409
Ya. What we wanting to do.
I don't have anything designed yet but I'm looking into adding options to the catalog soon.
matmerri1
matmerri1
Lansing, Michigan, USA
Thanks.
IMG 6448
I may be willing to part with a couple. DM me. If you want a pre-made harness, I'm sure we can work something out.
