Requirements: Honda Signature Accessory SWITCH PLATE/VOLT METER/WIRE HARNESS
0SA30-HL4-100
Welcome to Honda Pioneer Tech
KIT#11 950-HP1A-AA-LB05-180602, 5A LIGHT BAR SWITCH & HARNESS KIT. CONSISTS OF: 5A LIGHT BAR SWITCH, 18AWG 06' HARNESS WITH 2 POSITION PLUG, 11" ZIP TIES-QTY 3. APPLICATION: PIONEER 1000 3P/5P ALL YEARS. LIGHT MOUNTING LOCATION: FRONT BRUSH GUARD. KIT DOES NOT CONTAIN LIGHT BAR.
0SA30-HL4-100
- Requirements: Honda Signature Accessory SWITCH PLATE/VOLT METER/WIRE HARNESS must be installed in SXS before proceeding.
- Harness is constructed with tough 18 AWG wire, 6 foot in length, sheathed with flexible PVC tubing that is gas and oil resistant.
- Harness Plug is a 2 Position Plug that will only fit either "AUX LIGHT" or "LIGHT BAR" 5 AMP plug in Accessory Fuse Box.
- Harness Plug has splash proof gaskets installed on the base & plug
- This is a 5 AMP rated harness that will support a 60 Watt device
- Led Light Bar switch is a Heavy Duty, 20 AMP, non-lit rocker that will plug directly into the Honda Switch Plate Accessory Harness.
- Each harness is hand built and tested in the U.S.
- Contains 11" zip ties, Qty. 3
- Instruction sheet is included with kit
- LIGHT BAR IS NOT INCLUDED
