P1000m5 Honda Pioneer 1000 M5 Deluxe Specifications
66,869
Pioneer 1000-5 Deluxe
ENGINE
Engine Type 999cc liquid-cooled twin-cylinder Unicam® four-stroke
Bore And Stroke 92mm x 75.1mm
Compression Ratio 10:1
Induction Fuel Injection (PGM-FI), 44mm throttle body
Ignition Full-transistorized with electronic advance
DRIVE TRAIN
Transmission Fully-Automatic Dual Clutch Transmission (DCT) with six forward gears and Reverse. Four drive modes include 2WD, 4WD, Turf and Differential lock. Dual Range Sub-Transmission.
Transmission Paddle Shifters with three shift modes (standard, sport, and manual)
Driveline Direct front and rear driveshafts
CHASSIS / SUSPENSION / BRAKES
Front Suspension Independent double-wishbone; 10.55 inches travel
Rear Suspension Independent double-wishbone; 10 inches travel
Front Brake 210mm hydraulic disc
Rear Brake 210mm hydraulic disc
Front Tires 27 x 9-14
Rear Tires 27 x 11-14
DIMENSIONS
Bed Capacity 1000 pounds
Towing Capacity 2000 pounds
OTHER
Note Recommended for Drivers 16 years of age and older.
Available Colors Red, Metallic Silver, White, Honda Phantom Camo®
Model Id SXS1000M5D
FACTORY WARRANTY INFORMATION
Duration One Year
Description Transferable limited warranty; extended coverage available with a Honda Protection Plan
  • Pioneer 1000-5 Deluxe.pdf
James connolly
What's the price on the p 5
