And that's all you could ask. Sounds like Manly Bugs' machine isn't doing that.fishin2Dmax said:...yes, it did lack power at the highest altitudes, but it had enough bottom end torque that it made it up anything I needed it to.
I did some calculations last night, and using the formula for elevation power loss ( HP Loss = (elevation x 0.03 x horsepower @ sea level)/1000 ) with the CARB sheet given spec of 36ish HP, the Pioneer would lose approx 9 HP at 9-10000 feet. 27HP at the crank. A dog, but not like his machine.
I'm going to ramble for a minute, and its not directed at anyone in particular...
If there is one area of purchase that concerns me with the Pioneer, its power. Well...not actual power, but the varying reports owners give of how good or bad this drivetrain is at pulling. Some say it will pull a house, while at the same time you get the odd report of these machines bogging down at the drop of the hat.
The same thing happened to the Rincon when it came out..and to a lesser extent, the big red ( due mainly to limited numbers ). Early Rincons had a problem with some o-rings that weren't installed properly and low oil pressure resulted. This lead to the Rincon receiving a mostly undeserved reputation.
Then there was the oil TSB. The Rincon/Big Red/Pioneer transmission is unlike any other ATV/SxS...and in reality, unlike anything. Yes, its just like an automotive auto, but car trannys don't use engine oil for lubrication. They use much thinner fluid. I think its clear that Honda ideally would like to use something thinner, but can't in this situation. And you get the "bogging", "slipping" and "sluggishness" that owners report in really cold weather before the machine is warmed up.
The point of all this is that this drive train is uber sensitive to oil, oil pressure and viscosity, and the symptoms are not always what you'd think they would be. MB and i talked on another thread, so i know he is still using stock oil and tires, but if something were slightly amiss and the pressure was a little low...well, that could be the reason. Maybe a sensor is biased, but not enough to trip a code? I would b**** at my dealer until he checked all this out...and maybe try another unit to see how it runs.
If these tests proved to be ok, my one last shot would to be to try thinner oil ( i am of the opinion that these machines should always use the thinnest oil possible for a temp ). Maybe 0-30 or even 0-20...if a motorcycle oil can be found in that weight, and see what it does. If you want to know why this would make a difference, Google converter flash RPM and tranny fluid types. The answer will be on a drag racing forum.
If it still displays this behavior, I'd trade the thing and send Honda a nasty letter. No way should this machine not be able to pull itself under any reasonable circumstances. Snow at 9000 feet is reasonable for an off-road vehicle, and I've never had an ATV that didn't run out of traction ( in lower gears ) before it ran out of power.
Posts like Manly bugs concern me. I already have a deposit down, so i am dedicated..and i think there are probably explanations for them because, if there weren't, that would mean that Honda simply dropped the ball here...something it rarely does. I admit i will have a hard time believing that until i see it for myself..but the number of "i pulled a house" posts make me think that something is just amiss.
I'm through ranting now.
