P1000 Honda soft doors
Trevan
Trevan
27
66
Milton, ON. Canada
The supplied riv-nut is hard to install on the top of the plastic door and get it aligned vertically. This makes removal and replacement of the soft door a pain as its tricky to line up the fastener with the hole in the frame and the threaded riv-nut. If you have done this you know what I mean!
My solution was to insert a “stud” and use a washer and wing-nut to fasten the soft door.
So far so good .
330C1E2C 86F9 41F6 90B9 4165F0DA9652
C4C77006 D764 48BE 8F00 3873A5C8B46D
BD084703 95BA 4CC5 A93E 71B1A13DC878
TripleB
TripleB
11,722
99,575
Caryville, Tennessee
So far so good .
View attachment 374386View attachment 374387View attachment 374388
Good idea
tjoreo
tjoreo
1,011
1,929
Southern Idaho
The are a pain to get lined up. The first door I installed them in I didn't pay much attention and just marked the hole half hearted. When we went to install the bolt it was a big pain to get in. The next door I paid better attention when I installed the rivet nut and it lined up better. We finally took a drill bit to the hole in the frame and enlarged the hole in the upper frame. That helped with the install and we ended up doing the same to the other door. Alot of times in the fall and late spring I throw my doors on and leave these rear bolts out. Looks like your solution should work well.
Vikes79
Vikes79
SKOL!
10,884
105,611
South Dakota
  2. Talon X4 LV
On mine I found that the uppers fit better and seal up a bit better with a nut that is approximately 3/8” inch tall as a spacer between the frame and the door. It also makes the angle more tolerable for the bolt.
the other option is to make the top hole on the tube a little bit bigger.
