P500 hondacare extended warranty
W
Workingman
Belleville il
I bought a used 500 sxs fella said it only ran one tank of gas through it it was like brand new. I noticed soon after buying it their was a like tingling noises from rear of engine maybe muffler never thought much about it. Anyways it started smoking blue smoke once warmed up . I took it in dealership said it needs a new motor factory rep had to look at it first . Factory rep cked it out said dust damage or dirt damage from maybe loose air box is what dealer said they said . Dealer said it won't be covered under the extended warranty which I transferred as soon as I bought it about a year ago. Machine has around 650 miles on it rep from Honda said it wasn't serviced correctly or some bs reason not to cover expense. So its gonna cost 2400 called Honda customer said it is what it is. this is a drag..
208,730
Should have some other repair options, like independent shops. If it sucked a lot of dust I could see an over sized piston, rings, bearings and a bore job, maybe some valve work.
182,378
What I gather from the story is that little P5 had about 100 miles on it when you bought it...due for first service. Sounds like it didn't get it?Now the machine has 650 miles on it, atleast a couple yrs old and no one has ever opened the air box or probably serviced anything. That does suck and I'm sorry to hear that but chalk it up as a lesson learned the hard way. Takes about a minute to get to the air filter. :rolleyes:
208,730
Yea! Bummer! This is a single cylinder engine and I could see this getting repaired for a whole lot less than $ 2,400.00
208,730
Two years old and one tank of gas? Wonder if you have a ring stuck? I would try some Marvel Mistrl oil. Take the spark plug cap and air filter lose, crank it while spraying oil in the intake and let it set a couple days.
Reactions: Mudwing
W
Workingman
Belleville il
well dealer said fella I bought it from did have the 100 mile service done whatever that involves . I changed the oil once it is do for its 600 mile service or somewhere close to that dealer said it was do about 50 miles ago. Just seems odd that you can buy a damn new machine heck I could of ate off it and 600 miles later it needs a engine . Honda rep said piston is bad and its loose on crank shaft I can't believe it won't be covered hell all I do is put around on my fathers farm . Kids have rode out some but not that hard. What the heck is the extended warranty good for if it won't cover repairs ? Just ticks me off something bad...
Reactions: Fordman and trigger
208,730
That's why I didn't buy the extended warranty! Games!
Russ989
Russ989
22,642
147,257
I agree Smitty335, nothing to lose at this point.
Reactions: Mudwing
Triggers slappin chops these days, must be loosing patience in your old age. :D:D But you are right.
I just bought a new rig, came in to pick it up yesterday, was looking over the numbers. I asked what this $1,300.00 was and they said ext warranty. So I said take it off.
Reactions: Mudwing and trigger
I know right? Am I turning into that guy? :rolleyes:
What did you buy? o_O
A 1000-5, to leave at my NM property. The 700 isn’t doin it for me.
Reactions: trigger
XterraGoat
XterraGoat
Louisiana
  2. Other Brand
Word of advice... Raise enough hell with the honda customer line and point out you have extended warranty... They'll take care of it.
However, strictly speaking, dust in the intake is NOT a warranty issue unless something was incorrectly installed from the factory.
AlR
AlR
470
1,166
Nanaimo, British Columbia
$2,400 for a new motor seems like an incredible bargain to me. I can't imagine that includes labour. It takes about 12-14 hours just to remove the motor. I didn't know you could get a 'motor in a box' for the P5. In Canada you can not get a motor... you have to buy all the parts separately. Hard to imagine dust hurting these tough little machines. Sounds like a no-oil situation.
Reactions: Gassygordo
Bbarker
9
16
East kentucky
Just went through kinda same thing,1000-3,what sounded like valves chattering turned into complete engine failure.extended warranty did cover but no one could get it back together right.NO HELP from Honda,reps are a joke.after seven months dealership replaced with a new one picking it up today!
Reactions: trigger
Bbarker
9
16
East kentucky
no Honda won't help,the answer you get is extended warranty is a third party nothing to us sorry
Fordman
Fordman
160
272
Fayette Al
Sorry to hear about this, a guy I work with had a P700 about 2 months & changed the air filter to a UNI or K&N (can’t recall) dusted the engine & Honda blames it on the air filter! They told him it must be a factory style Oiled filter ! I Dunno , now he says he’ll never buy a Honda again I told him they all have issues, just thought I’d share with you
Reactions: Bbarker
Mudder
Mudder
NTC Ambassador of Walls
11,692
88,500
Use of equivalent aftermarket products, service, should not void warranty, Magnuson- Moss law. Just have to prove equivalent.
