P1000 How are you guys strapping down the Odyssey battery?
EricG
EricG
177
162
North East PA
Got the PC925 and just trying to figure before I go installing stuff how you guys are strapping them down. I see they make a strap that uses J hooks you can buy for this battery. I assume most guys are bending a metal bracket and just screwing them down? Thanks in advance!
Reactions: adnoh and Ragnar406
Ragnar406
Ragnar406
The Great Bald One
4,446
17,020
Bella Vista, AR
I just took an old strap and cut a hole for it to go underneath the plastic and over the top of the battery
you can kinda see the strap under the fusebox below
IMG 3810
Reactions: Rottiedog and EricG
EricG
EricG
177
162
North East PA
They make a bar for this battery and it comes with J hooks. I was thinking of just getting flat stock, installing 2 tie down points (like small d rings) and getting J hooks.
Hondoman
Hondoman
727
1,697
Texas
I did pretty much the same. Cut a piece of 1/2" plywood to match the top of my battery. Rattle can rino'd it and the ran strap over it. Screwed fuse box on top of plywood.
20171028 155535
Reactions: Ragnar406 and EricG
EricG
EricG
177
162
North East PA
Thanks for the suggestions guys I appreciate it!
207,989
Mounted mine to the primary battery hold down strap with 8 x 32 pan head screws with nylock nuts
207,989
Got a pic by chance? I can't quite picture what you did there.
Can't get my dang phone to work, but I will try to explain it, drilled two holes in the battery strap, one at the front of strap on the flat 8 x 32 x 1/2 inch pan head, back, drilled hole on the down slope of the battery strap, used a 8 x 32 x 1 inch pan head, only used two screws, left enough slack in the wires to remove primary battery hold down strap and move it off to the side for primary battery removal. Does that make since?
EricG
EricG
177
162
North East PA
I'm just not picturing how you are utilizing the tie down for the primary battery to secure the 2nd battery. Are you saying you ran a strap from the factory tie down on the primary battery to the 2nd battery?
13,418
65,792
@EricG I think Smitty is confused. I believe he mounted his isolator to his primary battery hold down.
Reactions: EricG
EricG
EricG
177
162
North East PA
That makes more sense to me unless I am missing a piece of the puzzle.
8d218d4ccb38ff6e9bb420ce7b13f7c5
D13df8b19360093fb385d9a40284165c
I put the strap in a slot on one side and then bolted down on the other. It’s held since December 2015.
VenturaChuck
VenturaChuck
64
110
Ventura, CA
I used a large cable tie
Yep, I did the same thing. I used two large ties. One tight to hold the battery, then another left loose for a "battery carrier" when it's time to change the battery.
EricG
EricG
177
162
North East PA
I was actually gonna ask you how that held up. When I was searching I saw your older post and was curious if the plastic held. I was afraid of it cracking but I guess there really isn't a lot of force on it. Does it still work well for the ground for the Isolator? I was thinking of doing the same thing.
It’s been good so far with no issues.
So much so that I did the same thing on the “Farm Rig” which is my fathers.
Reactions: EricG
EricG
EricG
177
162
North East PA
So I got the 2nd battery mounted down. I had a piece of flat stock with holes predrilled in it. I bent it to form around the battery. Towards the front of the battery box I screwed down a small corner bracket (3/4"x1/2"). I attached a J bolt to that. Towards the rear I did as others have done and just screwed the bracket down and will use it as a ground point as well. I also put 2 small pieces of felt on the backside of the bracket. Everything should hold up well I hope. Thanks to everyone for the ideas.
Battery1 Battery2 Battery3 Battery4 Battery5
Now I gotta start rewiring stuff. Joy Joy!
