How low is to low on the voltmeter
Sxsnewbie
Sxsnewbie
298
103
Eastern Connecticut
I have a p5 with stock battery and am running a winch, 4 small LED spot lights, a light bar and a 12v car charger. When the sxs is running I'm between 12-14v. As I start turning lights on and using the winch it fluctuates down As low as 10 I think. Is this ok?
Short term yes but repeated doing this kills the battery. You should really keep the constant draw under. 450 watts(700-4 assuming it's the same size on the 500), around 37-38 amps at @12v as that is the alternators max output. But you need to consider the draw of the ecu and coil.
A winch will drain a small battery QUICK
Sxsnewbie
Sxsnewbie
298
103
Eastern Connecticut
I don't think it's same battery as 700.. As long as the machine is running, I should b fine? If I wanna put a stereo in I should look to a bigger or joint battery?
Not sure about 2015, 2014 700 has a 12ahr battery.
The charging system is what I was referring to not the battery. The 500 alternator is the same output, 450 watts. You draw more than that, it draws from the battery.
Sxsnewbie
Sxsnewbie
298
103
Eastern Connecticut
Got ya.. And I went for a night ride tonight. Had all the lights on (no winch use) and my meter was at 13... I must have saw the meter wrong at 10
Yeah using my winch it's around 10 even with the bigger battery. Difference is with the factory battery I have to stop for a few seconds to let it catch up because the winch slows down, with the bigger battery I can use it until I get out.
Also let's me run my radio for as long as I want.
Springer
Springer
312
234
what size battery did you install?
Optima Group 34....55ahr
