P1000 How to drive a P1k?
338fedman
17
36
Alaska
Newby here and just got my first P1k-3. 2016 with 1400 miles, all stock except 28” tires and a full cab and heater. original clutch cover intact. Reading tons on this forum and a wealth of information!
I have pieced a little about how to NOT drive these machines but could use more general guidance. What I’ve gathered so far:
1. If stuck don’t give it gas - winch out
2. Don’t do this in reverse
3. Run manual if you can
4. Use low more often
any other thoughts about the right way to run these?
Higher rpms vs low I assume?
I ran sport mode once and it seemed to shift really high so won’t do that again.
also, what’s the best way to tow a meat wagon with these?
I don’t plan on going bigger than the 28’s that are on it.
thanks for any wisdom, it’s greatly appreciated
Fyi, I have this at the dealer for the clutch update. Want to be sure it’s good to go.
NTCPrezJB
NTCPrezJB
Retiring Member
108,850
960,111
Hidden
Welcome to the forum from Canton, OH
Pics or it didn’t happen!
Red is the fastest color!
#NTC
The machine has clutch plates…you want them completely disengaged or you want them completely engaged and the tires moving accordingly. Not allowing the clutch plates to slip is the key to clutch life.
As for RPM…the machine has a rev limiter…don’t be afraid to hit it and bounce off of it when needed. But cruising around yeah up shift so the motor isn’t screaming for no reason. At the same time…don’t have the motor growling towards stall out for no reason either. If you’ve driven a manual vehicle you know the difference in the two extremes.
The machine isn’t an automatic…it is a manual with electronics helping or controlling shifting duties.
Low vs High … plenty of overlap between the two. Don’t use high to idle across the yard at 3 mph. Don’t use low to run 35 mph+ down the pavement to the gas station. Use your head and you’ll be fine. If most of what you are doing is on the slower end of things use Low, if you’re running fire roads and barely slowing down for washouts use High. Don’t be afraid to switch back and forth between the two as needed. Personally I’d only make the switch while stopped though.
Gabbas
Gabbas
280
701
Humboldt, Iowa
ONLY SHIFT WHILE STOPPED.
It's fine to give it has when stuck.,
Only if your tires are spinning. If they're not spinning don't give it gas
Shifting from low to hi while moving it not optional. Don't do it.
Just be smart and listen to your machine. If it sounds like it's "lugging" down shift. Etc.
Sent from my Pixel 4a (5G) using Tapatalk
115,792
66C3E9AA 62A3 4BD4 BD0D 70AF6576FBFD
1643810503098
338fedman
17
36
Alaska
#NTC
Pics will come when I get it back and start my mods. It is red, but really partial to the orange! Thanks for the feedback.
Todd627
Todd627
56,722
619,305
MI
5,433
24,963
I'm a short shifter and paddle up anytime I'm not in a hurry. You can't lug these (Talon in my case) because the DCT software won't let you, it will always downshift when necessary. I'm surprised at how low down in the RPM the motor will still pull. Every once in a while, it won't donwshift when I think it should, that's what the paddles are for (assuming your model has paddles).
Low or High - when in doubt, paddle down, if there's a gear below where you were, you were just fine. If there wasn't a lower gear, you could have been in low. As said - if the tires are turning, you can send it.
The software programming is so good that I use the auto mode 95% of the time (with frequent manual upshifts), that's up to you and your mechanical knowledge. I don't like high rpm but don't ride in extreme conditions either. Even when I'm doing my best Robby Gordon impression, I'm still 'paddling up', pulling hard on the torque band not high rpm HP. You can't upshift too far, or lug the engine too much, the software won't let you (being stuck is an exception and we're back to 'tires must be turning').
Be careful shifting into Low range, especially when cold, don't let the gears grind, even for a second. Read the first post linked in my sig, it will explain that.
PatioDaddyo58
PatioDaddyo58
48
95
Abilene, TX
john790
357
1,093
Clinton ohio 44216
I quess iam on the learning curve here.I know how you should run this thing with the clutch.But i have been working the dog chit out of this thing plowing snow.Back dragging a foot of wet snow pushing a foot of wet snow and pushing 4ft snow piles down to 2 footers hard crunchey snow.Last time 4 diff lock on the piles it did a nice job low range.I hope my clutch likes me
