P500 How to mount front dune flag
115,291
You taking a P5 to silver Lake? :oops:
I would get a clamp and put it on the back rack. Should be fine.
Reactions: Buggyman
115,291
In michigan the need to be mounted to the front of the vehicle
actually you don't. I live and from Michigan have ridden that Crazy dune hundreds of times. It just has to be tall enough to to see. Ive mounted them on the back many times. A P5 is so short like a quad on wheel base you should be good. To put it on the front, you will need to fab something unless u can get a clamp on that small so called brush guard up front.
Have fun with that P5 on SL, lower those tire pressures and either stay away from the big hill or give her hell cuz your gonna need it!
MI-Trailblazer
MI-Trailblazer
283
1,370
Parma, MI
Yep, local ORV park by me requires a flag as well. I actually fabbed-up a mount for my Blazer to attach to the tube bumper/baja loop on the front of it. So just adapted it for the P500 front bumper. Basically, a flat piece of steel with 3 holes in it: 1 for the flag and 2 for a U-bolt.
