ehart814
Well after some intermittent starter issues, she finally bit the dust.
This is a hard one boys, so stay with me!
Step one- get new starter
Remove old starter. It is accessed through the drivers side of the machine. It might be a bit easier if you remove the drivers side rear wheel, but it’s not needed.
NOTE: you will need to reuse the nut that holds the starter wire to the starter terminal. Do not remove the new nut that comes on the new starter - the wire goes over it.
Two bolts hold the starter in. You need a 12mm socket or wrench. Remove the bolts. One of them is also holding a ground wire. Then use a 10mm socket to remove the nut holding the hot wire to the terminal on the starter.
Move the wires out of the way and start yanking on the starter. It won’t be eager to come out. You can stick a screwdriver under the ear (where the bolt goes through) and pry while wiggling it. Eventually the old starter will come out.
Pic of where the starter was:
Now take your new starter and put some grease on the Oring.
Stuff it in the hole!
Replace the bolts, making sure to run the passenger side bolt through the ground wire...
Attach the starter wire to the terminal.
Start the machine and ride. It probably took me longer to type this post than to make the repair. Didn’t even take long enough to finish a beer.
Also, this job could be done on the trail if needed!
