P1000 I’m lost need help
Bigmanlittlebuggy
Bigmanlittlebuggy
158
442
Ellabell GA
So my i4wd light is on I just got done replacing drive shaft and installed a new rb3 billet rack I have checked all connectors seem to be in my programmer doesn't find any error codes fuse is good when I try to shift into 4wd the display doesn't show it and tried 2 wheel lock display doesn't change anybody have any ideas what could be going on or how to fix this issue?
Bigmanlittlebuggy
Bigmanlittlebuggy
158
442
Ellabell GA
Have you taken it for a ride? I'm no expert on i4wd but I've read on here that the wheels sensors need to reset. I'm sure someone will give you some ideas here
Once the parts where on I did ride it down the road and back noticed the light came on around a turn also found one of my axles in front had pulled out slightly causing diff fluid to leak wondering if maybe the sensor could not pick up the gear on the axle and that’s why it threw the light
Rayger143
Rayger143
3,096
27,188
Winfield, BC Canada
Probably onto something
DRZRon1
DRZRon1
1,207
3,901
PA
I am thinking here the pressing issue is why the axle popped out?
U have axles out to change steering rack?
Are left and right tie rods adjusted correctly?
etc….
Bigmanlittlebuggy
Bigmanlittlebuggy
158
442
Ellabell GA
etc….
Yea so I had to a bunch of repairs after a big ride had to rebuild axles and replace drive shaft and replace the rack but update after driving it again the light went off so It was the axle and it hasent popped back out again yet lol still won’t engage into 2 wheel lock or 4wd though thinking cables need to be adjusted because I went with bigger tires
