OK first thoughts after installing folding windshield, hard cab back and full length top. Windshield is below what I expected from Honda as it has some vibration noises compaired to my old EMP windshield on my RZR. This could be do to the additional length so I would rate as good. Back hard cab is nice only thing I would do different is on the corner pieces don't drill holes marked by honda hold up clamps and mark holes after corners are in place. Minor problem rateing the cab back very good. Top fits well and rate very good also.
After just ideling around off the trailer and into the shop I was impressed with how quiet this thing is then I drove around the block and was shocked by the engine/gear train ? noise. I have read the posts and was expecting this just not as bad as it is. Will be going thru everything today to check for loose/missing bolts, fluid levels, tire pressure and a general check over the whole machin before my first ride.
