I have an intermittent issue with my ‘21 P1000-5 LE where the i4wd warning light comes on when I brake hard, ie pulling a trailer and apply the brakes. I’ve already been through warranty claims for cable adjustments and even a locked up caliper where a bolt came loose and lodged between the pad and the rotor. The I4wd seems to be working perfectly except for this occasional, short term warning light which goes away after I turn the machine off.
My question - is this a normal quirk or is there still an I4wd issue lurking in the background. I would like to figure this out before I get out of warranty. Any insight appreciated.
