caddyman
Guys
I had this done on a '17 LE-3 not long ago and figured I would update you all. I had a chance to take it out on a better test drive than what I did at dealership. In auto mode the shifting does not seem right. Noticed on some of the gear shifts the RPM's would go higher than normal then sound normal until the next shift. I have experienced this prior but it was very random and wasn't any specific gear. Kinda like that shift didn't sound normal but may never happen the rest of your ride. Manual mode seems fine as I use that most of the time anyway. Also there was snow, so part of my ride I had it in I4WD. When only accelerating I would hear a strange clunk in the drivetrain. My only thought it was due to it being in 4WD and dont know if its related to the odd shifting in auto mode. I always warm it up for 10 or 15 minutes before riding. Needless to say I called the shop and was told that is normal shifting after the clutch cover update. I cant imagine this is normal after reading other posts that had this update done. He did say part of that install was to re-program something. I also complained about how long it would take for cluster to register drive modes i.e turf, 2 wheel lock. Adjustments were made. Any thoughts on this? current miles 700 and clutches looked fine. I like the dealer and trust what the tech tells me but something just isn't right. Perhaps I need to go on a longer ride. All I can say its not the same after I got it back.
