in need of help
L
LBBB
louisiana
hello from louisiana, i have a 2016 pioneer 1000-5 and i have recently noticed a ticking noise coming from the engine area of the sxs, the noise only seems to happen when under a load, i don’t notice it at idol. i’m not real sure what it is, I’ve done some reading on the forum and haven’t really figured much out. could this be the valves need to be adjusted or the chain tensioner needs to be tightened or replaced? any help is much appreciated. thanks in advanced.
G
Gohonda2
46
252
Mississippi
How many hours/miles on it? Have the valves ever been adjusted?
L
LBBB
louisiana
miles and hours are high, i’m not sure if the valves have been adjusted or not i bought the bike used a few months ago and i just noticed the sounds starting to happen yesterday afternoon
P1K5Dave
P1K5Dave
2,244
8,419
Petoskey, MI
Your p1000 will always sound "ticky" under load when it's running a gear higher than it should. Either hit your left downshift paddle, or go to sport mode (depending on what you're doing. )
L
LBBB
louisiana
i’ll try it in sport mode tomorrow and see if that helps any, thank you for the information that would be my problem my pioneer is bigger then most so i try to keep it in a higher gear for cruising around. i guess i just never heard it over the radio
Reactions: Farmer and JenElio
HBarlow
HBarlow
1,614
6,004
Daniels, WV
Without basic information it is very difficult for anyone to offer useful suggestions.
Reactions: Robobrainiac
Russ989
Russ989
22,642
147,257
^^^^^This^^^^^
You can help it by servicing the sub trans and adding some Lucas oil additive to it as well.
Reactions: LBBB
P1K5Dave
P1K5Dave
2,244
8,419
Petoskey, MI
I use sport mode for long, moderate trail hill climbs. Not big hills that require some wheelin', just the ones that my Pioneer likes to run up a gear or two higher than it should.
Reactions: WagginTail
WagginTail
WagginTail
1,577
5,827
SC
Yep. Sport Mode works great for this
