I have three indicator lights that are mounted on the plastic cowling covering the handle bars. Today my Reverse light went out, but it came on for a little while after I moved the wires behind the light. Do these lights come out by popping them out with a screwdriver? I thought I'd switch the light that indicates "TEMP" with the reverse light since the overhead sensor doesn't seem to work anyhow (the "Temp" light come on and off randomly).
I just don't want to pry out the lights and crate a problem. FYI there are 3 lights mounted on the handle bar cover, 1) Reverse, 2) Neutral, and 3) Temp. Thanks for any info.
