@Chevyfan396
I built a heater system a few years back for my Pioneer 500. Used a heater core from JEGS, same as sold from summit racing.
New 2018 Pioneer 500 owner here. I’ve had it for about a month now and it has been great. Here in northern Idaho the snow will keep me out of the mountains for about 3-4 months but early spring and late fall is ridable but can be downright chilly. So I set out to enclose my cab. I bought a...
hondasxs.com
Sealed up the cab as best as possible and blocked off the dash leaks like the 4wd lever, pedals, and reverse lever. Its good but always looking to bump the efficiency up as the 500 doesn't throw a lot of heat.
Do you have your heater core plumbed out side the thermostat or did you use a bypass/relocation valve to access the coolant behind the thermostat? I did not use a bypass or relocation. So the whole external circuit needs to be hot to pass much heat to the core. A lot is lost to the radiator doing it's job, especially at higher speeds. I blocked my radiator off with a piece of cardboard and it made a world of difference. Essentially turning the heater core into the radiator. Just gotta remember to remove it when temps warm up.
I thought about the re-circulation idea at one point but my inlet isn't as conveniently located as yours and scrapped it. Though I see where 3d printing might just make it possible. Nice job with this project.
