P700 installing blower to cut down on engine heat
2Track
2Track
21
45
I could use some electrical advice. I'm putting a blower with a switch underneath my seat to help control engine heat. I'd like to tie into a positive and neutral wire that's connected to the switch that allows no power to my blower unless the engines running. Does anybody have an idea what wires I should tie into coming off of the electrical near the battery that would do this. I want to do it this way because I don't want to risk the fan being left on when the engine shut off.
Scoop
Scoop
5,130
20,278
  3. Talon R LV
Nice I'll take a look at that!
Here ya go. No cut key-on power harness for your 700, among others.
If you plan on adding any other accessories, spend a little time searching the forums for posts by folks who have added fuse boxes and other related items.
Or consider the Auxbeam 8 gang panel. Makes adding more accessories much easier. I have a half dozen Carling switches but needed switched power when I added my bilge blower/fan (like you want to do), so I added the Auxbeam panel.
Mudwisel
Mudwisel
8,652
74,306
Tampa Bay Florida
I think if you just add the trigger shield you will accomplish a satisfactory result. I have done basically the same thing and it really cuts down on heat and it’s ready to go and machine specific
177,981
I think if you just add the trigger shield you will accomplish a satisfactory result. I have done basic the same thing and it really cuts down on heat with is it’s ready to go and machine specific
Thanks Oso. I was going to suggest that but didn't want to come across as pushy. But yes, in a P7 you really don't need the bilge fan, a shield will suffice.
Mopower58
Mopower58
CST is the Best!
79,418
706,150
Crystal Springs,Ms.
X2, although I have a P1000 I also have a heat shield from @trigger and it works wonders with the heat. Never had a bilge fan but I live in the heat in Mississippi so I am used to it.
115,290
Yea sir! Your shield works for the heat fo sho! A bilge fan helps with the steam you get from water hitting your exhaust
2Track
2Track
21
45
The shield would have been good but I already have the bilge fan so I'll go with that first. But does the 2020 700-4 have an accessory plug in the rear somewhere? I've found the one in the front. Thx
Mudwisel
Mudwisel
8,652
74,306
Tampa Bay Florida
There is a plug for back up lights. Not aware of one for accessories
toddvdh
toddvdh
1,103
7,286
Green Bay, WI
I guess if you back up a lot that would be fine. 🤷‍♂️
  • Haha
