P1000 Installing switch panel
Bartman
Bartman
80
126
Maine
For those that have installed custom switch panels on the dash where the big safety sign is, what have you found is the best tool to cut the plastic out with ? I've got one of those Harbor Freight multi-tool cutters I was thinking about using.
sporttrac4x4
sporttrac4x4
1,177
2,082
ILL.
Just drill the rivets out
Reactions: Revtech100
Upstatefreedom
Upstatefreedom
224
410
Colton,New york
I have already removed the sign. I have ordered a few switches for lights, I'm not going with a self contained switch board, so I'm going to cut the switch holes with my dremal tool with a rotozip bit. Should work well. Imagine you could do the same.
sharp
sharp
3,757
14,955
Tennessee
I used my pocket knife to cut the plastic for the switches. It worked great.
Reactions: CumminsPusher
Mattdean
Mattdean
50
68
Florida
I just used my pocket knife as well
sharp
sharp
3,757
14,955
Tennessee
Yes the lawyers were on that one! I wonder if we're all going to prison for removal lol
Sent from iPhone
Supposedly the warning label is a safety device, and if removed it voids the warranty, because it gives you driving advice which covers them. I don't know if it's ever been enforced. If so I guess I'm out of luck. Lol
319,870
Should have kept it I guess to put its wrinkled up sticky back across the switches for service
Sent from iPhone
Reactions: Eltobgi
319,870
Even a razor knife works really well for the square holes. That plastic is really soft so it's really easy no matter what's used
Sent from iPhone
Reactions: Eltobgi and sharp
Bartman
Bartman
80
126
Maine
I bought one of mystic1219 panels, 4 switches, an outlet hole and Ram mount, so I need to cut out most of that rectangle. I also want to give two thumbs up to mystic's panels too, very high quality and priced right.
319,870
Unless you already have power don't worry too much about what you use especially with one of Mystics panels anything works great
Sent from iPhone
Reactions: sharp
7,140
27,147
I used air powered jig saw and utility knife to clean up the edges.
May be someone should try leaving the sign and just cut holes for switches in it.
Sent from my SAMSUNG-SM-G891A using Tapatalk
PioneerPete
PioneerPete
1,496
3,516
Chattanooga, TN
I used a cordless jigsaw to cut out the big hole for a mystic switch plate. drilled the rivets and peeled the warning sticker first.
GlockMeister
GlockMeister
The Bearded Wonder
7,604
35,567
Greenville, Mo
I used a dremel with a cutoff wheel..just used a sharp chisel to cut the heads off the rivets. That glue they put on the warning sticker..dam. they didn't want it to come off
ClemsonTiger
Wilmington, NC
Razor knife. Use the switch mounts found on Amazon as the template. I removed the rear warning signs as well. Who needs them back there?? Haha
20160914 150152
20160914 150206
