Instruction Manual Issues
Clarky
108
Anyone else having issues downloading the accessory installation manuals? I have had issues with it failing part way through the download. Now, I am having issues with saying "There was an error opening this document. The file is damaged and could not be repaired.". Anyone else having issues?
43,590
I had the same issue for the 4p hardtop one. Had to use the 2p one.
Many of them are in the gallery here.
Clarky
108
Yeah, that is actually what I used, and it saved my butt. Many thanks to you or whomever put them out there.
Why would Honda not have valid links to this stuff. When I opened the switch panel box, all you get are website URL's that don't work. Also, I couldn't find the templates for drilling the holes for the switch plate & fuse box. I had to use the actual pieces as a template.
TandT
TandT
357
22
Newark, Ohio
Clarky. You did good using the actual pieces, as I have seen templates that wasn't even close to where you should drill. Anytime I can I use the actual part.
