Have a 2020 pioneer less than 1k miles. It sometimes will go into what seems a limp mode. This happened out of nowhere. The gears will shift from park to reverse etc, but it will sometimes will only stay in 1st. Any ideas?
Just joined, welcome from South Florida 🤘Have a 2020 pioneer less than 1k miles. It sometimes will go into what seems a limp mode. This happened out of nowhere. The gears will shift from park to reverse etc, but it will sometimes will only stay in 1st. Any ideas?
You can always try and do a clutch relearn. That's help some issues in the past. Also make sure oil levels are good and voltage is correct. DCT is very finicky about bad voltage.definantly not the seatbelt.
Welcome from Michigan!Have a 2020 pioneer less than 1k miles. It sometimes will go into what seems a limp mode. This happened out of nowhere. The gears will shift from park to reverse etc, but it will sometimes will only stay in 1st. Any ideas?
Could this switch be shot? The wires seem connected.Check the wires to your neutral switch
I’ll take some. It doesn’t see mud or trails. It’s just a machine that works around the property.Welcome from Michigan!
Like stated above, pics of machine required or….PICS OR IT DIDNT HAPPEN!
With the 1k miles, how much is ripping on trail, Ideling or putsing around?
If most of it is the ladder, change your spark plugs. They will foul quickly that way and when u go to put it in gear, voltage and such matters fo sho… but if u have a fouled plug it will do what your describing as well. Your also on yr 4 of your stock battery. Do a Load test with a LOAD TESTER not a meeter on that battery. Simple things first, work smarter not harder.
Yeah I checked some wires. Seem solid. How many grounds exist?Maybe check your grounds also, seems to be somewhat of an issue with the electrical system ....
yeah it did that but after running it a bit. I’ll try to replicateIf the gear indicator is stuck in 1st and it is flashing the 1. Count the series of long and short pulses and that will tell us what code your machine is throwing.
Pic of her
Oooooo shes perdy! GO BLUE!I’ll take some. It doesn’t see mud or trails. It’s just a machine that works around the property.
I believe there are three (3) main grounds to the engine, I also believe there's a location diagram floating around .............maybe try the search bar for that one ......Yeah I checked some wires. Seem solid. How many grounds exist?
If the number "1" was flashing it is telling you a code and where maybe to start looking. If it does it again count the long and short flashes or even take a video of it. We can then check the service manual to see where to start.Yeah I checked some wires. Seem solid. How many grounds exist?
Tires probably have to be replaced later this year. They seemed to not lastOther than the tires that thing looks brand new! Welcome from Tampa, Hopefully you get it straightened out.
It just did it. Seems like long flashes and 2 short flashes at the end.If the number "1" was flashing it is telling you a code and where maybe to start looking. If it does it again count the long and short flashes or even take a video of it. We can then check the service manual to see where to start.
How many long flashes?It just did it. Seems like long flashes and 2 short flashes at the end.
Sorry 5 long 2 shortHow many long flashes?
The amount of long flashes followed by the amount of short flashes = the code
5 long 2 short.How many long flashes?
