P500 Is it safe to use a Portable Battery Booster to Jump Start ?
Bcraig
154
267
Arkansas
I carry one of those battery boosters in my Truck .
Very convenient and can air up a tire (Albeit slowly)and has a Light on it as well.
Just want to know if I ever have any Issue with the 500 not starting can the Booster be used to start the Honda ?
Thanks
lee
lee
Village Idiot
2,443
13,833
Springfield Ohio
No problem.
12 volts is 12 volts.
Once a p5 is running it will work just fine as long as the battery is just dead, no need to leave a jump battery hooked up.
5,744
26,371
No problem.
My Antigravity MicroStart has protective circuitry to disconnect shortly after it sees charging voltage because that’s too many amps for the AG to handle. I’m sure many others are like that. My point - if you have a catastrophic battery failure, the small battery pack won’t run the vehicle, it will have disconnected itself.
Bcraig
154
267
Arkansas
I have one in mine right now as the battery is going bad, I just clip onto power supply to bus bar under hood and good to go.
I am unfamiliar with the bus Bar
Where is it located under the hood ?
Reactions: Fatsquatch
Mudder
Mudder
NTC/TAP Transition Member
11,865
90,386
Ok thanks
What is its purpose ?
Like said, when running aftermarket high amp cables (ie. 6 ga) from the battery to the hood, consider it an extension of the battery terminals. I used the terminal post option, with a protective circuit breaker beside the battery.
A0CBF301 A8C0 44D0 A722 F13F6E0A0271 C071C260 3597 4878 B9A3 DE3439F406BB
Alan aka Davinci
Alan aka Davinci
Mr. Meme Master
16,808
183,554
Grand Junction, CO
Thanks
I carry one with me and have started many machines with it.
Reactions: trigger and Mudder
