P500 Is lugging ok?
Elmo7mm
Elmo7mm
25
90
I have a 2020 p500 and ride mostly dirt roads. I like to run around 10 to 15 mph and usually 4th gear. Is lugging at lower rpms ok on clutch. I'm not talking valve rattling lug just lower rpms.I also run 27 inch tires.
20200422 120159
F
Fischer
209
321
The woods
Can't do that on mine; it downshifts on its own even in manual. Mine's a 2018.
Yes that would make sense if his is a 2020 and it's not kicking down automatically then he has got no worries.
Reactions: TripleB
Elmo7mm
Elmo7mm
25
90
Yes mine will downshift on it's own in manual. Like I said I dont lug it low in a pull just like running lower rpms.
L2R
L2R
Understanding women Vol. 1
1,063
6,599
East of the Appalachians
I know of no cars that run in 4th gear at 10 or 15 mph.
If that was good for the engine, they wouldn't bother giving us the other gears.
Mudder
Mudder
NTC Ambassador of Walls
11,607
87,392
I try to keep the rpms in in the middle of the range on trails. If it downshifts under load, I consider it my bad. But on flats just cruising, a little less rpms. But like said by others, the computer should let you know.
lee
lee
Village Idiot
2,377
13,440
Springfield Ohio
Can't lug a AT even in MT mode.
Better yet, my wife and I put some miles on a 2015 p500.
She would slow down and lug it to the point it would stall.
If I said anything it wouldn't go well (could have been my choice of words).
If I didn't let her drive it went even worse.
I love the auto down shift on our 2018.
Honda added a feature I needed and I didn't even know I needed that feature.
-Bear-
-Bear-
NTC Master Fabricator
8,850
96,641
Black Hills, SD
www.facebook.com
  2. Talon X LV
Mine is a 2018 and it shifts own it's own even though I feel sometimes the speed and rpm's don't jive. Also when in auto, I can still use the paddle shifters if I feel my rpm's are too high or low. Not sure if that is normal, but I like it. For the most part I think it does great, never falls on it's face or just redlines the engine.
Reactions: Elmo7mm and Mudder
