P1000 Isolator and solenoid recommendations for accessories
L
Lapcinski
50
136
Minnesota
  2. Do not currently own
Hello there, this is my first post! I live in Minnesota and I am picking up my new Honda Pioneer 1000-5 this weekend. After reading a lot of the current threads, I was wondering if "True" is the best isolator or is there another with a better track record? Also, I read the Stinger solenoid doesn't like the cold and some recommended the Cole Hersee. Im wondering what the best solenoid is for the cold? How long are these two things lasting?
Thanks for all the great posts and information. This site is perfect excellent!
Jeff
2021 Honda Pioneer 1000-5 Deluxe. White
-Hard sided doors and mid panel
-Glass windshield and wipers
-Side mirrors
-Inferno heater
-Secondary battery
-Plow
Pictures to follow
Reactions: TxDoc
TxDoc
TxDoc
2,155
7,248
TEXAS 🇨🇱
photos.app.goo.gl
Welcome to a new Honda dimension. Great people and a lot of experience to help.
You might throw this on the list. Note the 100% buyer rating.
DAV11
DAV11
105
194
Minnesota
I'm probably not typical, but since I used relays on any accessories that pull amps I skipped the Stinger and just used a relay with a 30 amp fuse between the second battery and the added fuse panel. I'm just using the fuse panel for the switches and volt meters.
I also used the Tru isolator. Had it for about a year, no issues.
L
Lapcinski
50
136
Minnesota
Thanks for the info. Any thoughts on a solenoid for the cold weather?
Reactions: Lofar
L
Lapcinski
50
136
Minnesota
Thanks, I will take a look at them.
I like the hydro plow! How do you like it? Can it be installed on a different brand of plow?
Reactions: Lofar
DAV11
DAV11
105
194
Minnesota
If you can weld and make brackets to hold it, I would think it would work. I've only used it one winter so far. It worked well. Had to plow with the window cracked open since I was warm with the heat on in the cab. I used to plow with a Honda Rincon and that got cold.
20201118 172436
Reactions: Lapcinski
