P1000 Jegs Heater
P
packer58
301
908
N. Cali
Was looking around for a cost effective heater that would actually produce enough heat to keep the windshield defrosted and add a little heat to the cab. Found this heater on Amazon, the few reviews seem positive and the price is right. Would have to furnish all the fittings but that's easy enough, has anybody given this particular heater a try or have any first hand experience ??
https://www.amazon.com/dp/B07HB9M6TC?tag=sxsweb24-20
Reactions: ChadD
106,508
Same one that I have. Works well. A bit of a Whore to run the duckts and you will have to get some fittings to make the splices for your antifreeze lines. I have the jegs version. Its the same thing.
you will have to do a search for my full install with the bleeding of the system as well. Its mixed into another heater question/install That I didnt start.
The Date was back in 2018 I believe
Reactions: ChadD
P
packer58
301
908
N. Cali
Thanks, 4 or 5 years and no real complaints on performance sounds like a pretty good endorsement to me. I'll search out your build thread and take a look.
My initial thoughts were to run a single duct up front to a TEE and replace my cup holders with louvered vents to take care of the windshield.
106,508
That would work as long as you don't mind loosing your beer holders? Youll see i put mine on larger louvered vents just below the seat and angle them up. One other mod Id suggest with this is the fan override switch so u can get more heat out of the heater. Really made a difference
DRZRon1
DRZRon1
855
2,755
jegs, summit racing, etc. put a few in rzrzs for buddies, always got a 3 outlet unit, duct kits from them, center ducted to a t for defrost, the other 2 for heat, all worked well - literally save hundreds over the name brand/oem stuff if u have a thinner wallet
its not rocket science just a heater core/heat exchanger
Plowboy1466
Plowboy1466
290
1,453
Ashland, Ohio
I installed this Jegs heater and mostly followed the video on YouTube from Buck’s send it channel. It doesn’t have tubes for a defrost but it certainly helps!!!
P
packer58
301
908
N. Cali
Yep. That's the one. I'm pretty sure Buck is a member on here but l don't know what his handle is.
I looked a the vid, can't get much more direct than that. You'd definitely get as much heat as the heater is capable of producing. Glass windshield = gotta have defrosters ...................
Reactions: ChadD
Plowboy1466
Plowboy1466
290
1,453
Ashland, Ohio
I have a glass windshield and the heater still helps with fogging a lot as long as you don't cross a deep water crossing to make steam with the exhaust.
