P1000 Joint spring driveshaft
A
aspire
27
50
ottawa
I have a 2020 Honda Pioneer 1000 EPS and pulled the driveshaft off the sub transmission. The manual makes reference to a joint spring... but after removing the shaft I don't seem to have anything resembling a spring. I have looked inside the shaft and on the floor in the shop in case it fell out but found nothing. What am I missing here?
20210213 154124
Mopower58
Mopower58
CST is the Best!
79,566
707,221
Crystal Springs,Ms.
I've never had the driveshaft out of my Pioneer but my Rhino had a small spring in the rear driveshaft to keep slack out of the telescoping action I assume.
TripleB
TripleB
15,166
135,400
Caryville, Tennessee
What happened to your 2020 to make you tear into it? Hopefully someone with knowledge comes along and helps.
Reactions: TxDoc
A
aspire
27
50
ottawa
I can see what looks to be a small lip just inside the propeller shaft joint and am guessing the spring is supposed to sit on that keeping tension on the shaft to your point about telescoping. I have looked everywhere and can't find damn spring so my guess is it was missing from the outset. Yet another part to order....
