P1000 Just got my 1000-3p. What’s the word on tires/rims I am looking for bigger without portals just to see what folks are running.
TPWA83
FFA4326E 459B 4F29 8E6E E8D7DB7F5299
TPWA83
I have 14s but I am not a fan of not being able to rotate them since the offset is not the same, thus why I asked about rims too.
Reactions: wrhii
G
GWH
748
2,475
Las Vegas Nevads
Well this I can tell u,I run 29” bighorn 2.0s off a can am.They are rated 8 ply.The only modification on my 2016 p1000 5. deluxe is Elka ft shocks set at the original height.I run the 9s in the ft 11s in the rear.In my opinion this is the way to go.Stock suspensions no lift.
Reactions: TimG
Russ989
Russ989
22,588
146,743
I run 30x10-14 on all four corners.
772D2DDF 3753 4166 BBBD B40BE16C8B1C
Reactions: TimG
TxDoc
TxDoc
1,653
5,734
TEXAS 🇨🇱
photos.app.goo.gl
I have a 2020 Honda Pioneer 1000-5 LE. No lift.
Running Super ATV Intimidators 28x10x14. ...10 mm offset 14 inch wheel.
Very smooth on hard pack, clean and pull well I'm mud. Two inch deep tread. Side biters for paddle action.
Good luck on your new adventure
TPWA83
I went to the dunes in Oregon and I was fairly impressed with the bighorn 2.0 stock tires that are on it but I live in Washington right up against the cascade mountain range and besides the sand I am a huge fan of the snow! So low psi big balloon tires is what I need.
GPR1500SC
GPR1500SC
857
2,355
North East MO
  2. Talon X LV
29/11/14 Maxxis Big horn 3's
I like them on dirt and mud 👌
noisy on pavement, only 6ply rated I gashed 3 side walls on rocks 😞
IMG 20200719 193638372 IMG 20200719 193740662
Reactions: TimG
GPR1500SC
GPR1500SC
857
2,355
North East MO
  2. Talon X LV
1.5 inches on the back and 1 inch spacers on the front.
Factory rear wheels on the front
t-bear
t-bear
NE OK
I'm running the same wheel all the way around plus a matching spare.
Wheel = Method 409 with 5+2 offset.
Rear Spacer = RB3 Offroad 1" spacer
Tire = Tensor Regulator 28x10-14
Stock suspension (base model) and no rubbing at all.
Reactions: Ohio4x4
TPWA83
Right on thanks for the info, I really appreciate it this has been an eye opener with all the stuff that is out there. I have also been researching the world of performance tunes as well!
Reactions: TimG
JenElio
JenElio
65,053
608,908
Loxahatchee, florida
Welcome from South FL!
Cant help u much with your wheel n tire question since im still running stock but I know if u can't get/find answers here it probably don't exist. Everyone is real nice for the most part 😉 and if you need help spending some $$$ we're real good at that too.😂😂
#NTC
Russ989
Russ989
22,588
146,743
@ Russ989
Russ what tires are those? And what do you think of them (i.e. use in mud/rock and wear)? Stock suspension? Any rubbing?
They are Supergrip K9s, they’ve done well in everything so far. I can’t say anything about wear just yet. I have satv a-arms and a spacer lift. They would run and scrub if you’re stock.
Reactions: t-bear
Bohnt10
Bohnt10
RoostBoost Equipped...
39
NW Ohio
Congrats and welcome! I’m running Tusk Aramid Terrabite 30x10x14, Fuel 5+2 rims, 2” spacer rear, 1” spacer front, HCR front a-arms and SuperATV rear a-arms
ACB5F003 43AE 4553 A2B8 C907EDE5217A
