Kenda Bearclaw HTR 25x10x12 all the way around
hurld
hurld
129
159
I'm finally about to pull the trigger on new tires. I want to keep my stock rims and be able to rotate my tires from front to back. I also need to stay with 25" tall tires to keep the stock height so my Pioneer 700 still fits in my garage overhead door. My plan is to purchase (4) Kenda Bearclaw Htr 25x10x12, buy (2) factory front rims on eBay to mount on the rear giving me the ability to rotate front to back. Just wanted some input if this setup should work well? The only down sides I can come up with is increased steering effort with wider tires on the front. Thoughts?
Sent from my SM-N900V using Tapatalk
ehart814
ehart814
1,653
3,631
NWPA
The front will be much wider than the rear, I believe.
hurld
hurld
129
159
Thanks, I will research this a little deeper, from what I've read I thought the rim offset on the factory rear rims was 1/2" different than in front, so the front would be 1" wider than rear with front rims all the way around.........I think ;)
