P1000 KFI Winch Mount Concerns
amc019
amc019
480
592
Little Rock, Ar
Does the Honda mount provide the same amount of angle on the rope?
No I don't know which to order on Monday...
Tabascojunkie
Tabascojunkie
84
50
SE Louisiana
This is after the shims - I don.t have a "before" picture.
It's not great but I can live with it now.
That's quite a drop... is it possible to over wind vs. under winding the winch drum to reduce the downward pull? I should think that will chafe that line if the fairlead gets as much as scuff on it.
How much line did you put on the winch?
pct
pct
Lost in the hills
790
1,023
Letart WV
Thanks Ghost that is what I was the angle that I was wanting to see Thanks going to order the supueratv one monday will post pics when it comes in
281,031
Strong Made can solve all those winch line angle concerns with their front bumper, also winch is easy to access and out of the mud:
20160122 094438
20160122 094325
Reactions: ChadD and pct
ghost
ghost
993
1,874
BC
It's a wide spool with 65' rope - from the manufacturer that way.
There was a discussion on this forum about spooling from the top. Concerns are about line speed and winch brake- forward vs back, and whether the winch is designed to take stress from that direction.
I don't use the winch that often - so I think this will work for me.
The upward angle and squared fairlead design looked unusable before I made the 2 mods. Now it's ... I don't know - usable. Still as good as other options - unless you want to mount it like Jackal. That might be in my future if mine doesn't work out.
The Super ATV mount looks interesting but from the winch's perspective that will be pulling from the top. Not sure if winches are designed to work that way.
Reactions: pct
Johnny_C
Johnny_C
303
143
Western N. Carolina
I believe that the winch is a significant
part of the structural strength of the
KFI mount. Without it bolted in place
you are weakening the intended
design.
Also, does the Strongmade mount shown
in this thread bolt to the 1k stock bumper?
If it does, I don't how that can be any stronger
than the KFI.
John
I used the KFI mount to build my front receiver from. It flexed wicked bad! I checked all the hardware and it was tight. The plate was flexing/bending. I had to remove it and add gussets to stiffen it. I was afraid if I left it as it was, it would fail from fatigue.
281,031
design.
than the KFI.
John
Regarding your question, since I have both the KFI mount then removed it and now the Strong Made mount. The KFI is essentially two plates that do depend on the winch frame to act as a spanning structure of rigidity. The Strong Made base is fully blocked in with over twice the material than the KFI mount. Here is a close up of the Strong Made base that the bumper bolts over and the winch on the top of.
20160119 181350
20160119 182054
20160119 194932
nbomar
nbomar
4,416
17,855
Springdale, AR
I have the KFI on mine. You are welcome to look at it before you order.
Reactions: amc019
pct
pct
Lost in the hills
790
1,023
Letart WV
Hey Ghost i noticed that in the instructions from superatv they mounted the winch upside down making the rope come off the top in that case your rope would be almost straight according to your pic did you think of doing that I didnt till I saw the pic
Marine660
245
244
This may be the first time I get an aftermarket bumper for my winch....way to tight and low for the stock location in my opinion. Every mud hole and water puddle will cover or submerge a winch down low.
Reactions: pct
mikegzales
mikegzales
61
68
louisiana
I just installed the kfi winch mount and it doesn't seem very strong it mounts to the front diff bolts and to the lower bumper bolts. I have not tested it but It looks like it will bend I can make it flex by just pulling on the winch by hand but I don't have the bumper back on but all of the bolts in. The Honda mount mounts to the upper and lower bumper bolts and the winch sits angled back it looks like a much stronger design.
i have the same mount... so far no problems with a 4500 lb winch
Reactions: pct
ghost
ghost
993
1,874
BC
It's a good thought. Someone else tried something similar - can't remember if it was reverse spool or just pulling from the top. They had interference from the cross bolt (tie rod). I just had a look at mine and I think I'll have the same issue. I'll have a better view next time i use the winch.
I guess SuperATV thinks it ok to pull from the top but I'll check with Motoalliance before I try.
DUSTMIL
12
12
TIPTON IOWA
My kfi winch mount bent and grounded my winch out on the frame and melted the secondary ground cable in my main wire harness on the very first use. Cost me 450 and about 8 hours of labor to replace the wire harness. I will be going with a better winch mount in the future.
Reactions: ChadD
Kisssofdeath
Kisssofdeath
55
128
Greer, SC
Hmm, I hate to hear that. I had second thoughts about using my KFI winch plate after buying it. Only reason I used it was because the eBay seller would refund me.
Just-Snake
Just-Snake
6
Iowa
This little rod came from under my 1000-5 around the winch area when I was adding synthetic and swapping the fairlead. Any idea what this is?
Reactions: ChadD
281,031
The winch itself usually has four bolts holding left to right sides together. Are yours all still in place?
Agree, I would guess that rod if hollow is a bolt cover spanning the winch drum tying both ends together, or threads in each end for bolts to screw into.
Screenshot 20250324 123201 Amazon Shopping
Reactions: Smitty335 and ChadD
