Kilo and JTW’s epic two week adventure!!
319,892
Packing up now..and headed to Taylor’s Park.... we hope it doesn’t suck!
Looks like mainly dirt roads unfortunately but scenery is spectacular. Good group already assembled I’d love to meet them all. Have a good time buddy. More shenanigans
Kilo427
Kilo427
1,543
6,439
I don’t know how to explain Moab, the variety of trails, the drastic changes in environment and the sheer amount of trails is mind blowing. I have never ridden in a better area, you want easy and beautiful you can do it all day, you want to test your skill you can do that as well, tired of the desert we’ll drive 10 minutes to the mountains.
If I would suggest one place for anyone to ride it would be Moab. Although it always seems to scare Richard and he runs away.
So gear reviews:
RB3 spacers
the good: they performed wonderfully so far many off camber areas I have no doubt I would have tipped or rolled they were a literal life saver
The bad: nothing they have performed as advertised, my tires rub the plastic fenders but that’s because my fenders are not exactly in the right place from ummm let’s call it age. So no negatives
RB3 steering rack
The good: I got bound up in some rocks and snapped a grade 8 bolt on my Tie rods the steering rack took no damage and has worked wonderfully. I have no doubt my steering with stock tie rods would be way tighter with no play.
The bad: none it is a substantial upgrade over stock, just get help installing the top two bolts I’ll show that more on install thread.
Deltons tube doors:
The good: awesome doors, worked great for the heat I felt it increases my ability to see my environment on difficult trails. Put some thick roll cage padding they make a great foot rest to.
The bad: Nothing
Cfab tie rods:
The good: they are stout, I haven’t bent one yet
The bad: I did however break the bolt that goes in the knuckle it’s an easy fix though if you get them just pick up some extra bolts. I believe some of the problem obviously was my driving but a tapered shim or machined bolt to fit in the stuck 7.5 taper would likely greatly reduce the wear and chances of sheering the bolt.
Weule cage:
The good : I tipped over and hit hard and I have flipped it end over end with not a single bend. I can say it has saved me from injury and saved me from not being able to continue riding
The bad: it does increase weight but that’s an expected give and take.
Cfab A arms:
The good: great arms, very tough, great customer service
The bad: they do change your cv geometry so caution on extreme lock to lock steering. I do have a ball joint slightly loose but that’s after several thousand trail miles. I would buy again
IGR:
The good: makes trails much more enjoyable you can crawl rocks and I rarely find myself running out of power.
The bad: higher RPMs, not the easiest to install yourself
A side note to Honda: please make the radiator bigger and the fan bigger there is a significant amount of room for this to be done.
Hondasxs radiator override switch has eliminated 90% of my issues in this area and is a very cheap fix until the new radiator prototype is complete.
Overall trip damage: 1 rear axle, 1 tie rod bolt
Now time to explore Colorado a bit and see what it has offer. Arrived this afternoon at Taylor park and will be seeking out challenging trails tomorrow am.
P.S. superatv make some 2.0 axles for pioneers.
(EDIT: this has been done thanks superatv!!!)
FAB18BAA 73DD 4264 9D76 3F45057B1EFE A63FA4D6 5809 48A8 8F6B AD733E37FD9F 963D7A58 1DDB 4AEF ABF1 1D78968F1996 C1D27E78 986A 4A64 8C62 5B9767CCDDCC 0A2B44D0 C289 412C A107 D76E67E0A299 2F3F90DF 09B8 4423 92E6 858288BD4898 EF3AD909 76D8 42EE 8E49 AB73EB205D19 20129BAF D357 4366 9603 D427B0481939 5C9B34AE D572 41E0 8777 F960E3ACDC5C 9ABC2E41 0B38 4A82 976E A14844A78D67 0EBA5B04 65C2 47C1 A434 ECEBE18679F7 F886C71A 9E9E 48B5 915E 157C8FB4DD76 6DF9C9D8 A1F0 42BA B585 FA7CD5080283 E8F75426 016A 4ED4 900D EC045E6AEEE3 F59B9C3B BA34 45D8 9D77 5C44F20B581C B915D14F 9470 4645 A686 11CA33EFC5A0 332C3268 ABC8 432F 8870 006C16630771
RB3offroad
RB3offroad
1,702
4,753
Tempe, AZ
So gear reviews:
RB3 spacers
RB3 steering rack
Deltons tube doors:
The bad: Nothing
Cfab tie rods:
Weule cage:
Cfab A arms:
IGR:
P.S. superatv make some 2.0 axles for pioneers, just because you have had some design failures and engineering mishaps on the original version I have faith you can get the improved 2.0 dialed in
View attachment 153513 View attachment 153514 View attachment 153515 View attachment 153516 View attachment 153517 View attachment 153518 View attachment 153519 View attachment 153520 View attachment 153521 View attachment 153522 View attachment 153523 View attachment 153524 View attachment 153525 View attachment 153526 View attachment 153527 View attachment 153528 View attachment 153529
Nice Write up and great pics!!!!
Backwoods
Backwoods
32,310
331,630
Douglasville ga
That ride looks like no other . Nothing else like it anywhere. I hope y'all continue to have a good time with no broke parts and no one hurt.
Kilo427
Kilo427
1,543
6,439
Awesome pictures looks like good time's.
When you get over to Taylor make Shure to do the Italian Creek trail up Flag Mountain.
Did the upper Italian creek section the rock ledge with off camber area was pretty spooky I did video it so I will post when I have better service
GPR1500SC
GPR1500SC
857
2,355
North East MO
  2. Talon X LV
I thought the view off the top was great, you can walk right up to the edge and look straight down, but after all your Moab picture it won't be as impressive.
nbomar
nbomar
4,416
17,854
Springdale, AR
What surgery ?
Broke my ankle in two places and they are displaced. Need screws to put it back together. Also tore my Achilles’ tendon at the same time. Have to have surgery to re attach it. Doing it all Tuesday.
NTCPrezJB
NTCPrezJB
President of #NTC
100,471
898,031
Canton, OH
That sounds horrible! Hopefully there is a great story of what caused the carnage. If not feel free to lie and start it off with “I was running away from three hot horny strippers...”. or some such nonsense.
BWAF
BWAF
I get paid to pass gas
8,857
42,437
Carthage MO
Oh balls what did you do
