I have a large light bar (52") and a Boss snowplow on my machine. I also recently installed a dual battery setup with a fuse box, tru iso, and stinger relay to switch it on. Regardless I am getting a dim LED every time I power the snowplow up, down, or side to side.(Its hydraulic) Once I let off the switch, the light bar comes back on to full power.
So.... I realize it is likely from the draw. However, what would you guys suggest I do to eliminate this? Hook the LED Light bar back up to the stock battery since it doesn't draw as much as the plow and is using a different source so it isn't affected by the draw of power from the plow? Or is there another solution?
Any ideas are good ones! Thank you for the help!
Josh
Josh
