![dale5740](/data/avatars/m/3/3836.jpg?1457307987)
I wanted to put a light bar above directly above the fairlead location on front bumper? Has anyone done this with a double row led light bar or even a single any help would be greatly appreciated.
I put a single row on mine.I wanted to put a light bar above directly above the fairlead location on front bumper? Has anyone done this with a double row led light bar or even a single any help would be greatly appreciated. View attachment 11162
is the single bar bright at night? and is it spot or flood or both?View attachment 11223
so where do I start thank u for posting I really appreciate your time!! I am racking my brain trying to decide Im real picky. I can see that u are 2 please tell me about it if u would. very nice set up u have. whats the reasoning for the reese I can think of many but didn't know if u had a special idea? the cable lights up front flood or spot or both? light bar mounted just to plastic or something underneath? how about your switches all lights separate or some together on one switch? anything special in the back of pioneer? real nice tell me as much as u can but if not thanks for your time this is well thought out!
where did u put your side turn signals I don't see them on the fender?View attachment 11223
Nilight 12" used piaa brackets
bothis that light bar spot or flood or both?
Well thank you. I hooked up the lights including two more in rear, to the second battery by way of isolated. They light up all same time thru dash rocker switch. Great for off road travel. Light bar is a flood, rest are spots. Light bar mounted thru plastic with bolts and big washers underneath. My turn signals lights are mounted on front and back and sides for traffic next to you visibility for turning in traffic. Did not think the horn dealer put in was so great so I added an A-oohga horn for kicks. Lights give great visibility.so where do I start thank u for posting I really appreciate your time!! I am racking my brain trying to decide Im real picky. I can see that u are 2 please tell me about it if u would. very nice set up u have. whats the reasoning for the reese I can think of many but didn't know if u had a special idea? the cable lights up front flood or spot or both? light bar mounted just to plastic or something underneath? how about your switches all lights separate or some together on one switch? anything special in the back of pioneer? real nice tell me as much as u can but if not thanks for your time this is well thought out!
Oh by the way, the front Reese receiver can be used for towing shackle, tow bar etc., I mainly use it to move my trailers around. Easier to push and pull trailers around in tight spots, much more monouverable.so where do I start thank u for posting I really appreciate your time!! I am racking my brain trying to decide Im real picky. I can see that u are 2 please tell me about it if u would. very nice set up u have. whats the reasoning for the reese I can think of many but didn't know if u had a special idea? the cable lights up front flood or spot or both? light bar mounted just to plastic or something underneath? how about your switches all lights separate or some together on one switch? anything special in the back of pioneer? real nice tell me as much as u can but if not thanks for your time this is well thought out!
the spots are they all hooked together on the same switch?Oh by the way, the front Reese receiver can be used for towing shackle, tow bar etc., I mainly use it to move my trailers around. Easier to push and pull trailers around in tight spots, much more monouverable.
Yes, other than stock lights for road riding, all off road LEDs are on one rocker switch to light up the woods and they do. Just like high beams, need to switch them off for incoming traffic, don,t need headon on small back roads.the spots are they all hooked together on the same switch?
Did you have to cut the plastic grille so light would go back far enough ? I bought the same light you got and it sticks out a bit.View attachment 11223
