LED lights automatically turning on
1Ktrailrider
1Ktrailrider
183
282
Pennsylvania
My lights are coming on while it sits in the garage. And my interior LED lights on a separate switch barely come on. If I hit the switch on and off it will turn one set of lights off but they don't turn completely off. They are wired on 2 separate switches to a common positive/negative bus bar, on a separate battery. Did I really have 2switches fry at the same time while sitting in the garage??
Reactions: Isaiah
Advertisment
You have something feeding backwards through a circuit or missing a ground. I would suggest checking your wiring.
HUCK
HUCK
1,047
2,314
ARIZONA
BUT DOES THE GARAGE DOOR OPEN WHEN YOU PUSH ON YOUR BRAKE PEDAL
farmtimpioneer
farmtimpioneer
Wise Men Still Seek "Him"
549
2,079
Brookville Ohio
like Obanacreek said You have back feed, ground wires don't go thru switches unless you are grounding a lighted switch or you are using the switch to complete a ground to a circuit,,,
Reactions: Isaiah
70Bones
70Bones
888
3,779
New Brunswick Canada
I had the same problem when I hooked up my new fuse panel last weekend. The new fuse panel had LED's on it to light up when a fuse is blown. However, power flows backward through a diode and a small current was lighting up my driving lights, so I cut the internal wires going to the LED's. Problem solved!
Reactions: Isaiah
