P1000 Lift Kit Needed!!
BrophyCreek
BrophyCreek
496
3,061
New Richmond, WI
Houston, we have a problem. I just put Fox Shocks and new tires and wheels on my P-1000-5. The tires 28" but measure about 28.5". From all the posts I read on here, they should be fine without lifting or arched A-Arms. But, when I went to load it this morning to head to the take over I found they do rub when turned hard over. So, my questions is: What is the easiest/ quickest fix? I'm thinking a hi-lifter or similar lift kit. I don't want to add spacers to the shocks if at all possible. Any suggestions on a brand or specific part number for a kit that is just brackets etc?? What ever I get, I have to order today and ship it overnight out ahead of me. Will be in Dayton tomorrow, so can receive something there. Help!!
Reactions: BWAF
Dragon21
Dragon21
1,309
2,920
Raleigh, NC
Dont think a lift will fix it, I think your only option is forward a arms... but i could be wrong.
mine are about the same measurements and they rubbed with the HL lift kit turning hard left under compression. Had to do forward a arms to fix it.
Reactions: BWAF
BrophyCreek
BrophyCreek
496
3,061
New Richmond, WI
I was hoping that would not be the case. I did see on the Honda SXS FB page, someone had a Hi-lifter kit and a-arms for sale. I'll pursue that unless someone else has any better ideas...
Reactions: BWAF
Dragon21
Dragon21
1,309
2,920
Raleigh, NC
its ride-able like it is, so dont worry for takeover. Just be aware in technical sections when turning hard to go slow. I rode mine in WV like that and was fine.
Going with a-arms, superATV seems to be the way to go unless you want built in lift, then CFAB.
Reactions: BWAF
BrophyCreek
BrophyCreek
496
3,061
New Richmond, WI
I'll have to do something, the rub is the tire catching on the bottom edge of the fender flares. Don't want to bust them up. I can get by with just arms and no lift?
Reactions: BWAF
CPope
CPope
352
1,152
Pulaski TN
Yes you can get by with just the super atv a arms
Reactions: BWAF
BWAF
BWAF
I get paid to pass gas
8,864
42,478
Carthage MO
What's your wheel offset ?
BWAF
BWAF
8,864
42,478
Carthage MO
Sorry, been driving, heading to P/T. 4-3 offset
Would love to be heading that way .I ask wheel offset because I have a set of 235-75r 15 That measure 28.5 i went 5x2 hoping if the center wasn't to far out from ball joint they wouldn't rub ?
BrophyCreek
BrophyCreek
496
3,061
New Richmond, WI
It's really close to clearing. The tires I bought are really square edged. If they were rounded off like the Bighorns, they'd be fine. I hooked up with someone that is coming to Takeover and bought a hi-lifter block kit and arched a-arms from them. Quick install (hopefully) at the Takeover and I should be good to go.....
Reactions: BWAF
BWAF
BWAF
8,864
42,478
Carthage MO
Have a great time
zmnypit
zmnypit
203
270
alabama
If the ball joints are already installed you could do it in a couple hrs. Otherwise you're going to need a balljoint removal tool.
Reactions: ohanacreek and BWAF
