P1000 Light Bar Mount on Hard Roof
VenturaChuck
VenturaChuck
64
110
Ventura, CA
Has anyone used this mount (click below)?
Light Bar Mounting Brackets
I see if is for an 18" to 30" long light bar but I was thinking about using it for a 50" to 52" curved LED light bar for my P1000-5 Deluxe.
Ridem32
Ridem32
938
848
Terry
Looks like it should work. But I would put a bracket behind it to make it more rigid.
Reactions: JTW
Ridem32
Ridem32
938
848
Terry
To me $50 bucks is high for that set up. Would be easy to make. But you pay for convenience
Reactions: JTW
Yeah that's ridiculous for the same thing two pieces of angle will do. But personally I would not put it on the roof.. and if I did it would be attached to the rops as some on here have done.
KevinSC
KevinSC
286
306
I mounted mine low on the hood in front of the half windshield. I only drilled two small holes then removed the plastic and put a piece of steal to sturdy it up. I used the mounts supplied with the light bar and it is very sturdy, but I wanted mine down low. Up high I was worried about dust and fog, that is why I mounted mine lower than my eyes. I will try to get a picture of it on a few minutes.
Reactions: dotman1 and JTW
Ridem32
Ridem32
938
848
Terry
If you put piece of flat steel behind the plastic it should be strong enough. Make the flat piece of steal larger then the mount.
Reactions: KevinSC
KevinSC
KevinSC
286
306
Yep, I got a 1/4" FB behind mine, you will not move it unless the bolt that holds the hood on gets taken out somehow.
