P1000 Light bar wired too??
Jason W
Jason W
The Ginger Cracker
649
5,784
Western NC mtns
Thinking of wiring my lightbar to high beam,
My new trail has unmarked switches on bottom, dealer says they are for added accessories, where would I find the wiring fron them, having a hard time
GovtMule
GovtMule
13,354
129,946
Tennessee
You’ll need the wiring kit from the Club Store. Those switches have no power. If he hasn’t shut down yet @Hondasxs can get you exactly what you need.
Mopower58
Mopower58
CST is the Best!
72,978
665,660
Crystal Springs,Ms.
Mine is a 2016 model, but I ordered the kit from the club store that energizes the light bar when switched to high beam. I like not having the extra switch.
RacinJasonWV
RacinJasonWV
52
156
WV
Unless they changed something between 2023 and 24, the Trail should only have 1 unused switch on the bottom row.
Left to Right
Winch, Dome Light (center of seat), and Extra
IMG 0364
The Extra switch wires run up under the hood and should have a small dummy plug. At least I’m pretty sure that’s it. I believe the club store sells connectors for it with wiring. Or you should be able to cut and splice the short dummy ends of the factory plug.
IMG 0365
I purchased the LED light bar from the club store. It comes on with high beam and is plug and play. Mount is simple to install as well.
Backwoods
Backwoods
33,188
340,478
Douglasville ga
He said let him know if anybody needs anything message him and he will bring it to TO
Reactions: Mudwisel and TxDoc
Jason W
Jason W
The Ginger Cracker
649
5,784
Western NC mtns
Left to Right
Winch, Dome Light (center of seat), and ExtraView attachment 430123
The high beam on harness I definitely need, will save the switch for something else.
Reactions: TxDoc
Hillbillytnt
Hillbillytnt
525
1,944
Ky
I used a seven pin on off on switch with a relay and the high beam kit from the club store. It allows for the light bar or bars in my case to be either on with high beams on by their selves or off completely
Reactions: Backwoods and TxDoc
TxDoc
TxDoc
1,723
6,017
TEXAS 🇨🇱
photos.app.goo.gl
Also note those factory switches are only rated at something like 3 amps, so anything beyond a dome light you will want to use a relay with them to power whatever it is that you need.
I wondered about that. On my trucks, I have two light bars. I used two DPDT switches to have each light bar, off, on or on with high beams. But used two relays.
On edit.. Hillbillytnt That is what I did with my trucks
Sent from my motorola edge plus 2023 using Tapatalk
64,981
Not packing everything... But I'll throw a few of these in the box.
You will need to ask me for them.
Jason W
Jason W
The Ginger Cracker
649
5,784
Western NC mtns
We found what I thought was the plug, tested key on, no continuity to ground no power, fuses fine
20240524 095429
Reactions: TxDoc and Backwoods
GovtMule
GovtMule
13,354
129,946
Tennessee
??????????.View attachment 430166
If memory serves me correctly…you’ve got to run key on power to the switches, and then there’s a pigtail in the kit that allows you to hook up your accessories. It’s a simple process with the kit, I just can’t remember how to explain it.
RacinJasonWV
RacinJasonWV
52
156
WV
My understanding is that’s just wired to each pole of the switch. You tie in from there sending it whatever you want and it switches it. They are low amp so any much of a load will require a relay. Mine’s still empty for now, might use for a cooling fan in the future.
