Live Valve Steering Angle Sensor
HondaTech
Anybody with an Live Valve (2 or 4 seat) that have had issues with their Steering Angle Sensor?
If so I'd like to PM you for more information about what became of the situation.
ManofManyStangs
16
10
P'Burg KY
  1. Talon X4
I have a 4 seater live last trip while turning on pavement my power steering went out. Only time it has happened and not happened since.
PaulF
PaulF
1,462
4,815
@GBell posted this earlier today...
GBell
GBell
103
144
  1. Talon X4
I'm looking for answers about this sensor if you have any information?
Reactions: Brando941
JonCarp
Charleston WV
I read the sensor going bad makes the shock warning light come on? If so I’m in that problem now with 50 miles on it.
Reactions: DSig
It’s under warranty right?
JonCarp
Charleston WV
Yea they have it. It’s the steering angle sensor. 2 week back order on it.
PaulF
PaulF
1,462
4,815
Came in but didn’t fix the issue. Ordered two more sensors.
Jon,
I see a recurring theme on the net concerning LV warning lights...
Light (or lights) come on.
Dealer tries all kinds of diagnostics and repairs to no avail.
Owner or Dealer finds loose, corroded or broken ground.
Owner or Dealer fixes ground.
Problem solved.
One even had a broken off ground bolt in the engine that wasn't extracted and made the new ground bolt feel tight but the bolt wasn't actually clamping the wires.
Have you or your dealer checked all the grounds? Make sure there is no corrosion and that they are all clamped down properly and that the wires don't move?
DorkMissile
25
37
Twin Cities, MN
I will say on my machine after reading several had luck with checking the grounds I checked the one under the driver's seat (which had a small amount of corrosion - I cleaned & re-tightened), tightened the ground on the engine, and snugged the battery terminals after my previous ride. My light was on after about 8 miles on this trip
Reactions: TripleB
DorkMissile
25
37
Twin Cities, MN
FYI - I was informed by one LiveValve owner that the issue with his was that he had a shock partially loose it's nitrogen charge
Brando941
Brando941
Sarasota FL
  1. Talon X4
yes going through a fight with Honda and a dealer right now. Trying to deny warranty claim.
  • Angry
Reactions: Montecresto
