P1000 Looking for a sensor
Bigmanlittlebuggy
Bigmanlittlebuggy
158
442
Ellabell GA
Anybody know what sensor tells the buggy it’s in 2 wheel lock and 4wd there both working but it won’t show me on the dash that it’s activated any ideas?
Reactions: EMAW and ChadD
Bigmanlittlebuggy
Bigmanlittlebuggy
158
442
Ellabell GA
There single pin bullet connectors in the front diff. 4wd is near the rear of the front diff and lock is towards the front.
If I remember right their under plastic covers.
Is this it?
884CFB69 4339 4886 A1D0 0C8207AFD3D9
HondaTech
Yes, there are 2 of those, 1 for each position.
Most likely the 4wd is just bad or it's not actually engaging 4wd.
If the PCM/Meter doesn't see 4wd indicated, it won't show diff lock. Does it switch between 2wd and turf ok? It could be an adjustment in the rear box as well.
Bigmanlittlebuggy
Bigmanlittlebuggy
158
442
Ellabell GA
I only saw one of these on the diff I will look again but my buddy did break that wire wile we were installing the rack so maybe that’s why it will go into 4wd but not show it? And it will not show me going into two wheel diff lock either so maybe I messed up the rear one when I pulled the diff idk turf mode is not working either but I have the box soaking in penetrating oil cause screw won’t turn also any idea where I can get some of those connectors I can’t find them
HondaTech
There just a female bullet connector. I could get you a number for the connector part but it won't have the rubber hat/cover on it. Honda only sells them in packs of 25 I think though.
Bigmanlittlebuggy
Bigmanlittlebuggy
158
442
Ellabell GA
Update fixed wire and drove it switched from 4 wheel to two wheel still not comming up on dash any more ideas
