P1000 Looking for Wheels in all the Wrong Places
O
Olive
10
42
Scottsdale AZ
I want to put 14" X 7 (5+2) plain-jane utility steel wheels (no chrome, no spokes, just a plain black wheel) on my 2016 Pioneer 1000-5. Can anyone direct me to a shop that sells such a mundane item?
DrShotgun
DrShotgun
3,907
47,888
Southern Ohio
ITP Delta Steel Wheels are what you want. On Amazon they have 4+3 14x7 but I’m sure you can find 5+2 somewhere. If not a lot of guys run 4+3.
#NTC
O
Olive
10
42
Scottsdale AZ
#NTC
I chose 5+2 because I heard that they did not rub and no modification would be needed. Is that true for the 4+3 as well? With the 4+3, are any spacers needed to make the track the same, front and back? Thanks for your help with this!
TripleB
TripleB
15,264
136,399
Caryville, Tennessee
Spacers will be needed for any off set that is the same for all four wheels.
O
Olive
10
42
Scottsdale AZ
The 14 inch wheels I am finding have a 4/110 bolt pattern and my pioneer takes a 4/137. There are adaptors that are 1" thick. If I use the adaptor, does anyone know what offset I need to avoid rubbing? This is so darn confusing. Someone needs to make a chart and sell it to dummies like me! lol
DrShotgun
DrShotgun
3,907
47,888
Southern Ohio
ITP Delta Steel Wheel (Front / 14X7 4/137 4+3) (Black) Compatible with 11-19 CAN-AM COM1000XT https://www.amazon.com/dp/B07N1Y69ZR/?tag=sxsweb24-20
Lady01
Lady01
192
488
Midland Michigan
Love the simplicity!
Reactions: ChadD and Blownzuki
TripleB
TripleB
15,264
136,399
I currently have stock steel wheels (variable size front and back) and I want plain-jane steel wheels ( same size 14 inch front and back)
You could get another set of stock 12 inch steel wheels and tires. You can usually find take offs cheap and use the 4 front wheels with 28x10x12 tires. You will only be 1 inch more narrow in the rear than in the front which you will never notice. That's what I have. Unless your hell bent on 14 inch wheels.
O
Olive
10
42
Scottsdale AZ
So if I buy the ITP Delta Steel Wheel 14X7 4/137 4+3 wheel, it won't rub? And, I will need a 1" spacer for the rear wheels? Just verifying...
One final question:
I found these and am ready to pull the trigger.
As far as you know, I have found the correct wheel, even though the website says that it will not fit my vehicle when I put in Honda Pioneer 1000-5. Correct?
JenElio
JenElio
73,387
667,551
Loxahatchee, florida
One final question:
Those should fit just fine, website might say no because the P1K is actually a 4/136 bolt pattern not 4/137. But they fit, lots of guys run 4/137 👍
