Lower Gears/Shorter Tires
pgiannetto65
pgiannetto65
97
155
I think the 1000 is a bit too high geared in Low, High, and Reverse. What if I was to get shorter tires? 26"? 25"? I believe Rangers are 25" tires.
What do you guys think?
It would definitely help the gear ratio. It would make it easier to get in and out of.
However, it would hurt off road performance.
69,056
If you went to 25" you would only lose 1" of g.c. but someone said it would drop gearing 7%.
Reactions: pgiannetto65
pgiannetto65
pgiannetto65
97
155
Why do you think it would hurt off road performance? I had a Ranger with 25" Sedona Rip Saws and it did everything I wanted it to do.
pgiannetto65
pgiannetto65
97
155
Nice video but I think I could die that with 1" shorter tires
If your needs are not compromised with slightly less ground clearance, I'd say go for it. It should give better gearing, lower center of gravity and maybe better acceleration.
Less us know how it goes.
CashMoney
CashMoney
329
211
Reno, NV
www.SRTNV.com
I think you could gain all you said, but you'd also lose top speed and hit the governor faster in low range since guys are saying its speed governed to like 35? But even that might be negligible since the speedometer will be off less at slower speeds
CashMoney
CashMoney
329
211
Reno, NV
www.SRTNV.com
Looks like if you went to a 25" your speedo would read 7% off. So when you're doing 35 you'd actually be like 32.5 and at 60 you'd be around 55.6
pgiannetto65
pgiannetto65
97
155
Thank you everyone for replies
272,194
That isn't really the case, those 27" Bighorn 2 that Honda P!K is using are only 25.5" tall @ 14 PSI if you measure them. So dropping to a true 25" tire will be little to n difference.
69,056
Yea there not real bighorns! Non of them are. Except the ones you buy aftermarket!
dale5740
dale5740
886
417
mt airy md
unless the 25's are really 23's lol
hondarock
hondarock
81
66
And the ones that come on a Polaris are the real deal.
dale5740
dale5740
886
417
mt airy md
This reminds me of some of the nikon scopes coming on some of the new riffle packages!!!! try and find a nikon like that directly from nikon u can't do it only found on the gun packages!!!! I asked my friend before I bought the 1000-5 about the bighorns when I was trying to decide weather to get the 1000-5 or deluxe he said real nice tire when I got it i parked beside his my tread was half what he had!!!
Stauvo
Stauvo
633
910
Minnesota
Will the aftermarket Bighorns 2.0 have more rim guard to protect the front wheel? Currently they look very inviting for sticks and rocks.
