I'm nearing the point of purchasing an Aluma 7712H trailer. The primary duty will be to haul my PK3 but it will also be used for hauling motorcycles, my mower, etc. Based on the feedback here, my current plan is to use Mac's tire nets to secure the PK3 to the trailer.
Does anyone have experience using Mac's Double Stud Anchor kits as tie down points on an aluminum trailer? The are spendy and don't offer some of the conveniences of e-track but they also take significantly less space, require drilling significantly fewer holes and will work better with many of my other planned uses for the trailer. Mac's claims the 3 small machine screws, locking nuts, and backing plate offer 5,000 lbs minimum break strength. This is even when installed through just the extruded aluminum trailer deck and not through stringers, frame rails, etc. Has anyone had experience using these in sudden stop or hard braking situations? If so, how did they hold up? Would you recommend them? I guess I'm surprised the small plate is enough to keep them from pulling through the extruded aluminum floor but I'll admit I'm nowhere near being an engineer.
Double Stud Anchor Plate Kit with Idler - 1" Fastener (4-Pack) | Mac's Custom Tie-Downs
www.macscustomtiedowns.com
