P1000 Maintaining dual battery set-up
Bubba
Bubba
100
124
Belle Chasse La.
What tender do you use ? That may be my problem, mine never goes to float mode, I don't think it is my accessories. Winch, light bar, led cab light and bilge fan is the only things hooked to second battery.
9b37eb69cf2c2e36625159dc4d1318ce
Reactions: sharp
My tender just puts out 0.75 amps, that might be the problem.
Still shouldn't be an issue as long as there is not a parasitic load. It is still putting power in.
With AGM battery you do need an AGM compatible charger.
With Lithium you need a Lithium compatible charger.
Reactions: sharp and truc577
Z
zin01
174
235
Royse City
What kind of battery is the stock battery. I'm not a battery guru I just know that optima is supposed to be good in these applications because it is gel? And a bigger battery means I won't run out of battery as fast. I hope.
I'm guess the stock battery is gel or AGM. Especially since it lays on its side and its spill proof. That's something I need to look into.
Optima uses fiber glass instead of gel. They're great batteries and you won't regret doing that mod. Just don't forget the isolator!
pmward
pmward
136
303
Galena, Missouri
Stock battery is absorbed glass mat...AGM.
Reactions: joeymt33
Chevy412SP
Chevy412SP
102
126
Western New York
I think that may be the key right there. Your using a 4amp charger where most I am going to assume are using the .75 amp or 1.25amp Battery tenders which aren't keeping up with the blue light staying on therefore it never goes into float mode and the green light on the battery tender never comes on. Being a 4amp charger it can keep up with the battery drain of the blue light on. No expert, just a thought there.
Doug_Jones
Doug_Jones
Sapulpa, Oklahoma
I have the dual battery setup and my primary battery is getting old. If it fails, can I jump start the motor from the secondary battery, and if so, how should it be done?
MC_Crowbar
MC_Crowbar
29
52
McAlester, OK
I suppose at it's most basic, just using a pair of jumper cables would work... but other than that it sort of depends on your setup. I'm in the same situation, my factory primary battery is showing age, whereas my aux is new. I've debated wiring up a switch to allow for jumping off the aux battery, but I'll probably just build a customer jumper wire to tie the positive terminals together (or jump the aux + post to the starter solenoid).
Doug_Jones
Doug_Jones
Sapulpa, Oklahoma
Thanks for the replies. I thought about the jumper cable but not knowing much about electronics I wondered if it would mess up something. I’m guessing I would only need one cable since both batteries are already grounded to the same vehicle frame.
