P500 Mobile 1 75w140 syn gear oil
Moose308
386
289
im a mobile 1 whore just my preference after trying pretty much all of them and all pretty much equal
Someone told me you can't mix synthetic with regular axle lubricant because it will tear up the gears.I did see where mobil 1 has gl4 and gl5 specs.I did use it one time in a 1998 Ford ranger and the rear end went out.Maybe coincidence. I run Mobil I oil in all my vehicles even the Duramax. Not sure on this axle situation.
jak9922
jak9922
hot headed wopolock
3,283
5,636
pittstown ny
Drain and fill ull be fine thats like saying u cant run syn oil in your car cuz it will cause all your gaskests to fail lol blah blah blah better is better there are still ppl saying carbs are more effective then fi
hambone
hambone
154
89
Southeast Indiana
I agree, synthetic is the way to go.
Although I haven't put any in the engine yet, of the P5 anyway.
maddmax
257
231
Clarksdale Ms.
Just installed mobil 1 75w140.The front housing appears to hold more volume than the rear.I was kind of surprised at that.
Well after reading you guys post i bit the bullet this past weekend & changed the rear & front gear oil with motorcraft 75w-140 syn oil and OH WHAT A DIFFERENCE IT MADE-best $22.00 ive spent so far.THIS IS THE BEST WEB SITE I HAVE EVER JOINED----THANKS GUYSFOR THE INFO
solrus
solrus
1,629
2,511
Montana
FINALLY got around to changing the dif fluid and definitely made a huge difference in the rearend noise and thats what i was shooting for :) yay go me pats on the back lmao
Would you change oil right after you bought unit? I just got it 2 days ago and reading this post , was thinking if I change it now I would reduce that noise. Please advice.
The Green Goat
The Green Goat
2,416
17,801
Ohio
What's the stock diff oil? I'm probably gonna throw my Torq Locker in tomorrow, but the diff only has about 20 miles on it. I'd like to continue to run the stock stuff to allow a good wear/break-in before switching over to some thicker synthetic. Plan is to run it for 3 days at PTO with the stock fluids, then change everything over to synthetic when I get home as it should be well past the 100 mile mark by that time.
jak9922
jak9922
hot headed wopolock
3,283
5,636
pittstown ny
you wont have an issue swapping it out
